September 26, 2022 at 9:33 am
FAQParticipantFAQ – Repositioning Heads Up Display (HUD) in Discovery
The size of the Head Up Display (HUD) can be adjusted from File Menu – Settings – General – Heads Up Display Size. The default size is Comfortable and can be switched to Compact or Wide as per your choice.
However, you sometimes might have noticed that while you are performing some operation or specifying any Boundary Conditions, the Heads Up Display covers the geometry of interest. In such cases you might have to re-orient the model or zoom in/out to visualize the geometry. In addition to these options, there is one useful option for repositioning the HUD. The option shown below helps to reposition the HUD.
If you click and drag it, the HUD will move along with your cursor and you can place it at some other convenient location.
- Discovery Downloads
- Ansys Discovery – Supported File Formats
- Release Notes- Previous versions
- Importing an Autodesk Fusion 360 Design Study into Ansys Discovery
- Ansys Discovery: Transient Simulation
- Top New Features in Ansys Discovery 2026 R1
- Ansys Discovery: Creating Custom Shortcuts
- Ansys Discovery: Customizing the Ribbon Tab
- Discovery SpaceClaim – Scripting examples
- Ansys Discovery 2025 R1 Capabilities chart
