September 26, 2022 at 9:59 am
FAQParticipantFAQ: KeyShot license error when rendering from queue
Problem:
When adding tasks to the rendering queue and clicking Process Queue, KeyShot produces the following error:
Solution:
This problem can be resolved by setting the KEYSHOT_EXTERNAL_LICENSE_FOLDER environment variable to point to the current Discovery installation folder for SCDM:
C:Program FilesANSYS Incv201scdm
- To access the Windows Environment variables, click the Start menu and search for “Environment”
- Select Edit the System Environment Variables
- Click Environment Variables…
- In the bottom section of the dialog box, locate KEYSHOT_EXTERNAL_LICENSE_FOLDER, click Edit, and set it as indicated above.
- If the variable does not exist, click New and create it
- Restart both SpaceClaim and KeyShot
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- How to setup a Parameter Study
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
- Discovery SpaceClaim: Getting Started Tutorials
- Creating a Helical Geometry in SpaceClaim
- FAQ: Missing Areas of the User Interface in Discovery Live
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
