September 26, 2022 at 9:59 am
Watch & LearnParticipantFAQ: How to Create a Custom Drawing Format in Discovery SpaceClaim
This video is part 3 of 3 in a series on model setup and customization in Discovery SpaceClaim.
Part III shows how to define a drawing format. When set as the default format, this file will be applied each time a new detail drawing is created.
Parts I and II of this series can be viewed using the Open Playlist icon in the top left corner of the video frame
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
