September 26, 2022 at 9:58 am
FAQ
ParticipantFAQ: Discovery AIM – Selecting multiple Selection Sets in a single boundary condition
By default, Discovery AIM allows selection of only one Named Selection at a time. However, it is possible to select multiple Named Selections using an expression. For example, if you would like to select “top interior” and “bottom interior” Named Selections for defining pressure, you can write an expression as mentioned below:
Add(GetSelectionSet(“@top interior”),GetSelectionSet(“@bottom interior”))
This expression needs to be entered in the “Location” field as shown below.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
- FAQ: Missing Areas of the User Interface in Discovery Live
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
