Failed to check out license ‘hfsshpc_pack’. License server does not support this license (FLEXlm Error – 18)
Tagged: 18, Analysis (HFSS), Electromagnetics & Electronics, hfss, hpc
May 25, 2023 at 7:30 am
SolutionParticipantThis is a common error when the HPC License type is set incorrectly to HPC PACK license instead of HPC POOL license. Below are the steps to modify the HPC License options. 1)Modifying HPC License Options From the ANSYS Electronics Desktop window, select the menu item, Tools > Options > HPC and Analysis Options… Click the Options tab, under HPC Licensing, select Pool for the HPC License options and click OK button.
1. Failed_to_check_out_license_hfsshpc_pack_FLEXlm_Error_18.pdf
- Cloud Computing from Electronics Desktop
- How to enable GPU acceleration in Electronics Desktop?
- How to import/export an Ansys Maxwell model in Workbench?
- How to fix messed up Windows layout?
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- What are the available boundary conditions in Maxwell?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- How to create and manage a queue of simulations?
- ANSYS Electronics Desktop: Simple Communications Channel For Signal Integrity Analyses – Part III
- Are solid losses and eddy losses the same in Maxwell?
