Tagged: 19.2, Analysis (HFSS), Electromagnetics & Electronics, hfss, hpc
May 25, 2023 at 7:29 am
FAQParticipantthe error message states that there is a license error due to requiring the HPC to distribute the parametric variation of a simulation. This normally requires a separate license called DSO. the parametric variation can still be done but in series and still using the HPC to distribuite the frequency points as required. In the HPC and Analysis option please select the configuration needed and then press the Edit button followed by the “job Distribution” tab. in this last please uncheck the “optimetrics variations” and leave only the “frequencies” checked on.
- Cloud Computing from Electronics Desktop
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- What are the available boundary conditions in Maxwell?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- How to create and manage a queue of simulations?
- ANSYS Electronics Desktop: Simple Communications Channel For Signal Integrity Analyses – Part III
- Are solid losses and eddy losses the same in Maxwell?
