Exporting geometry from ICEM to Rhino fails with the error: — Unloading existing geometry Loading C:/Users/STEVEP~1/DOCUME~1/2019 AIAA PAW/M=3 Inlet/Icemcfd/3D_GEOMETERY.tin Error opening file, C:/Users/STEVEP~1/DOCUME~1/2019
Tagged: 2020 R1, CAD Interface, fluid-dynamics, General, icem-cfd
March 17, 2023 at 8:58 amFAQParticipant
This error turns out to occur because of the spaces and the “=” in the filepath. In general it is safest to steer away from -@#%&=+!() and spaces in file paths and names.
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
