EWF model fails with floating point overflow I am running an EWF model simulation that is very simple. There is no DPM splashing and only one-way coupling between the film flow and the fluid flow. The run fails almost immediately with floating point overflow even though I am using very reasonable timesteps for the fluid.
January 25, 2023 at 7:17 am
FAQParticipantThe immediate failure of an EWF simulation is almost always due to non-convergence of the EWF solver. The EWF model has an option to post its solution residuals to the Fluent message window If you note these, they will usually be very high (1.0e+9 or higher) right before the failure. You can switch to the variable time-stepping mode for the EWF model to let a better sense of what the timesteps should be, but often this also allows the timestep to increase to overly large values. If this is the case, set a constant small timestep for the EWF solution (1.0e-06 s, ie:) and reduce the fluid timestep by one order of magnitude or more. The fluid and the film flow may not be coupled, but the film model has to adjust every time the fluid solution is updated, If the change in the fluid solution is too large, the EWF model will not undergo enough residual reduction to properly recover, and significant solution error will start to accumulate because of the transient nature of the film solution.
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- What is the superficial velocity in multiphase flows?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
