Eulerian Wall Film (EWF) is not created even though all settings concerning DPM injection and collection, and film initial or boundary conditions at walls are properly set
Tagged: 16, eulerian-wall-film, fluent, fluid-dynamics, MP - Eulerian MP Flow, multiphase
January 25, 2023 at 7:17 am
FAQ
ParticipantWe have to ensure that the minimum film thickness (defined in the ‘Solution Method and Control’ tab of the EWF model) is smaller than the initial film thickness defined on the wall boundaries, and any of the film thicknesses expected during the calculation. If the minimum film thickness is defined too high in these regards, then the max_cfl value for the film will report a value of 0 and the film temperature and velocity will assume the wall properties. A good habit besides that is to define a separate material for the DPM material such like we will have for instance water-liquid for the secondary phase and water-liquid-particle for the discrete phase particle.
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- What is the superficial velocity in multiphase flows?
- Mixing Tank Modeling in ANSYS Fluent
- Hydrodynamics and Wave Impact Analysis
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- How do I use porous media in a multiphase flow?
- What do “incomplete” DPM particle tracks mean?
