March 17, 2023 at 2:15 pm
FAQParticipantThis error message is due to the Inner Band. To resolve this issue, check the following: 1) The model should have both a Band and an Inner Band. 2) It is advised that the Inner Band is segmented. Please use the same segmentation as the Band. 3) It is advised that the Inner Band is located between the Band and the moving objects.
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- What are the available boundary conditions in Maxwell?
- Cloud Computing from Electronics Desktop
- How to create and manage a queue of simulations?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- Are solid losses and eddy losses the same in Maxwell?
- Parameters in HFSS 3D Components and design level variables
