[error] Project:プロジェクト名 Design:デザイン名, Solving adaptive frequency … (Domain solver), process hf3d error: Error in using BI boundary or IE region: couldn’t find any boundary associated with IE region(Hybrid 設定名_対象オブジェクト名)
Tagged: 2021 R1, Analysis (HFSS), hfss, HFSS-IE (Integral Equations)
January 31, 2023 at 9:25 am
FAQParticipant発生ケース IE Region 使用時で、メッシュ生成後 Adaptive 解析でエラー 原因 ・IE Region に設定していたモデルに問題がある場合には、たとえメッシュがエラー無く切れたとしても IE Region は使用不可 対策 ・IE Region に使用するモデルに問題が無いかどうかを確認
- [info] Failed to delete temporary files on server ‘localhost’. Found File ~ . You may want to manually delete directory ‘~’.
- [error] Solving adaptive frequency …, process hf3d error: Matrix solver exception: file I/O failure.
- [error] Doing Multiple Region Initial Mesh Assembly, process mesh3d : Unexpected internal software error. Please contact Ansys technical support
- [info] Normal completion of simulation on server: Local Machine.
- MPI 分散計算が行えない場合のチェック項目
- 一台の PC に複数の NIC (Network Interface Card) が有効な場合の Intel MPI の必要設定について
- [warning] For magnetic materials it is recommended to solve for at least 5 inductance passes.
- [info] Failed to start next variation. Analysis will stop when all running variations are finished.
- [info] A variation (変数条件) has been requested using the following machines: Local Machine
