Error message ‘Failed to copy local file xxx to file yyy. Error: The system cannot find the file specified.’
May 25, 2023 at 7:29 am
FAQParticipantGot to Tools > Options > HPC and Analysis Options, select the active configuration and click Edit. On tab ‘Job Distribution’ disable ‘Transient Solver’ and click OK. This disables TDM and the error message disappears.
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- What are the available boundary conditions in Maxwell?
- Cloud Computing from Electronics Desktop
- How to create and manage a queue of simulations?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- Are solid losses and eddy losses the same in Maxwell?
- Parameters in HFSS 3D Components and design level variables
