September 22, 2023 at 11:02 am
SolutionParticipantSolution Overview: This error message appears suddenly during the calculation and when the error pops-up the simulation stops. Keywords: Maxwell, Error, Transient Magnetic, Electric Machines, Transformers, Inductors, Actuators, Sensors. Attached you will find a document with the solution.
1. Solution_Error%20closing%20file.pdf
- EM FAQ: How to export the simulation results/plots of Maxwell?
- ANSYS Icepak: I get a meshing error – “Warning: no mesh exists for block, body”. How do I fix this?
- EM FAQ: How to define project variables that apply to all designs?
- EM FAQ: How to quickly fix or heal imported geometry in Maxwell 2D?
- What are the default boundary conditions in different solvers?
- EM_FAQ: When a DXF file is imported, how can you generate Areas from selected Lines?
- Vacuum Thermal Modeling in ANSYS Icepak
- ANSYS Icepak: How to delete unused materials in a project?
- ANSYS Icepak: O-grid meshing issues
- ANSYS Icepak: How to model a blower in Icepak?
