Tagged: 18, fluid-dynamics, General, workbench platform
June 5, 2023 at 7:05 am
FAQParticipantAs suggested by the error message, error was because DP0 had a different mesh file. Please change Solution properties > initialization option to “Solver Controlled” to ensure that DP1 would not use DP0 as an initial condition. Then error will not come.
- Skewness in ANSYS Meshing
