Tagged: 18, Electromagnetics & Electronics, File Import/Export, maxwell, modeler
September 22, 2023 at 11:02 am
SolutionParticipantAn imported 2D .dxf model may contains open lines, instead of covered surfaces. So, you may need to connect imported lines to create covered sheets. In order to create these areas, you can use the following options: 1. Select the uncovered (but closed) lines and go to Draw / Surface / Cover Lines 2. Select the unclosed (open) lines and go to Draw / Surface / Connect.
- EM FAQ: How to export the simulation results/plots of Maxwell?
- EM FAQ: How to quickly fix or heal imported geometry in Maxwell 2D?
- EM FAQ: How to define project variables that apply to all designs?
- ANSYS Icepak: I get a meshing error – “Warning: no mesh exists for block, body”. How do I fix this?
- What are the default boundary conditions in different solvers?
- EM_FAQ: When a DXF file is imported, how can you generate Areas from selected Lines?
- Vacuum Thermal Modeling in ANSYS Icepak
- ANSYS Icepak: How to delete unused materials in a project?
- EM FAQ: How to link the mesh from a static solver to transient solver in Maxwell?
- ANSYS Icepak: O-grid meshing issues
