May 25, 2023 at 7:29 am
FAQ
ParticipantYou should not apply mesh operations in lines because Maxwell 3D only can mesh 2D and 3D objects, If you do it the following error message will appear when you run the model: Process ‘G3dMesher’ terminated abnormally. It may have run out of memory or could have been killed by the user…”
- How do I calculate inductance and resistance of a coil in post-processing phase?
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to create and manage a queue of simulations?
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to fix messed up Windows layout?
- Are solid losses and eddy losses the same in Maxwell?
- What are the available boundary conditions in Maxwell?
- How to calculate capacitance and inductance in Maxwell Transient solver?
- How to perform a material sweep?
