General
General
EM_FAQ: How is possible to export TXT file of results that contain coordinates and values of variable, for example loss?
    • SolutionSolution
      Participant
      To Export a quantity (B field, Loss, etc) you need to: 1/ Open the Fields Calculator 2/ Introduce the Quantity you want to export for example Quantity -> Ohmic Loss 3/ Go to Output -> Export (introduce the file name and the values of the grid). A file will be generated with the Ohmic Losses in all the points of the specified grid. In the attached image you can see the steps mentioned above.
