February 6, 2023 at 2:42 pm
FAQParticipantAssume a distribution of magnetic field surrounding conductors with applied DC currents. The calculation of the components of the Lorentz force has the following steps in the field calculator. – Quantity -> J – Quantity -> B – Cross – Scalar -> ScalarX – Geom -> Volume … (specify the volume of interest) OK – ∫ – Eval The above example shows the process for calculating the X component of the Lorentz force. Similar steps should be performed for all components of interest.
- Cloud Computing from Electronics Desktop
- How to enable GPU acceleration in Electronics Desktop?
- How to import/export an Ansys Maxwell model in Workbench?
- How to fix messed up Windows layout?
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- What are the available boundary conditions in Maxwell?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- How to create and manage a queue of simulations?
- ANSYS Electronics Desktop: Simple Communications Channel For Signal Integrity Analyses – Part III
- Are solid losses and eddy losses the same in Maxwell?
