September 22, 2023 at 11:02 am
FAQParticipantInductance components are often seen in series of Maxwell Windings. Also they are automatically set when the excitation is generated from RMxprt. Those inductances allow to model physical inductances which are not modeled within Maxwell. It can represent inductances of input power cables or connections of the system. Often for 2D studies, it models leakage inductance of end windings which cannot be modeled in 2D. Keywords: Maxwell, Circuit, Excitation, Windings, Coils, Inductance, Leakage.
1. EM_FAQ_Why_adding_series_inductance_to_Maxwell_excitations.pdf
- EM FAQ: How to export the simulation results/plots of Maxwell?
- EM FAQ: How to quickly fix or heal imported geometry in Maxwell 2D?
- EM FAQ: How to define project variables that apply to all designs?
- ANSYS Icepak: I get a meshing error – “Warning: no mesh exists for block, body”. How do I fix this?
- What are the default boundary conditions in different solvers?
- Vacuum Thermal Modeling in ANSYS Icepak
- EM_FAQ: When a DXF file is imported, how can you generate Areas from selected Lines?
- EM FAQ: How to link the mesh from a static solver to transient solver in Maxwell?
- ANSYS Icepak: How to delete unused materials in a project?
- ANSYS Icepak: O-grid meshing issues
