September 22, 2023 at 11:02 am
SolutionParticipantRMxprt allows a user to define some design data in a text file which can be created by a text editor, instead of by RMxprt UI, for the following special circumstances: 1) Some special requests from a user which are not necessary to be added to RMxprt UI; 2) Some common requests from users which have been implemented in RMxprt solver, but have not been added in RMxprt UI. Keywords: RMxprt, User Defined Data.
1. Rev-How to set up User Defined Data (UDD) for a design.pdf
- EM FAQ: How to export the simulation results/plots of Maxwell?
- EM FAQ: How to quickly fix or heal imported geometry in Maxwell 2D?
- EM FAQ: How to define project variables that apply to all designs?
- ANSYS Icepak: I get a meshing error – “Warning: no mesh exists for block, body”. How do I fix this?
- What are the default boundary conditions in different solvers?
- Vacuum Thermal Modeling in ANSYS Icepak
- EM_FAQ: When a DXF file is imported, how can you generate Areas from selected Lines?
- EM FAQ: How to link the mesh from a static solver to transient solver in Maxwell?
- ANSYS Icepak: How to delete unused materials in a project?
- ANSYS Icepak: O-grid meshing issues
