May 25, 2023 at 7:30 am
SolutionParticipantUsing scripts is a fast, effective way to accomplish tasks you want to repeat. When you execute a script, the commands in the script are performed. You can write a script using any text editor or you can record a script from within the ANSYS Electronics Desktop interface. After recording the script from within ANSYS Electronics Desktop, you can then modify it if necessary using a text editor Keywords: Maxwell, script, IronPython, Visual Basic, Java, record script, stop script Please refer to the attachments to access the Solution.
1. EM_FAQ_Record_Script.pdf
- Cloud Computing from Electronics Desktop
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- What are the available boundary conditions in Maxwell?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- How to create and manage a queue of simulations?
- ANSYS Electronics Desktop: Simple Communications Channel For Signal Integrity Analyses – Part III
- Are solid losses and eddy losses the same in Maxwell?
