September 22, 2023 at 11:02 am
FAQParticipantSome simulations will successfully complete the model validation tests but fail to generate an initial mesh. This can caused by small features in geometry which has been created within the Maxwell environment or imported from external CAD. ANSYS Maxwell can attempt to heal the geometry in order to remove these features and successfully run the simulation. Keywords: Maxwell, Model, Error, Heal, CAD, ANSYS Electronics Desktop, HFSS, Q3D
1. EM_FAQ_How%20to%20quickly%20fix%20or%20heal%20imported%20model%20in%20Maxwell%202D.pdf
- EM FAQ: How to export the simulation results/plots of Maxwell?
- EM FAQ: How to quickly fix or heal imported geometry in Maxwell 2D?
- EM FAQ: How to define project variables that apply to all designs?
- ANSYS Icepak: I get a meshing error – “Warning: no mesh exists for block, body”. How do I fix this?
- What are the default boundary conditions in different solvers?
- EM_FAQ: When a DXF file is imported, how can you generate Areas from selected Lines?
- Vacuum Thermal Modeling in ANSYS Icepak
- ANSYS Icepak: How to delete unused materials in a project?
- EM FAQ: How to link the mesh from a static solver to transient solver in Maxwell?
- ANSYS Icepak: O-grid meshing issues
