September 22, 2023 at 11:02 am
FAQParticipantWhen used with the ANSYS Optimetrics module, ANSYS Maxwell can perform automated simulations by varying simulation parameters. Parametric sweeps are often used to gain an understanding of the performance of the design by making small changes and observing the results. By default, computed fields are not saved for every individual solution in a parametric sweep. This document explains how to modify the settings in order to save the field quantities during the parametric analysis and then how to display the saved fields after the analysis has been completed. Keywords: Maxwell, Electronics Design Desktop, Parameters, Parametric, Sweep, Fields, Save, Variables, HFSS, Q3D
1. EM_FAQ_Maxwell_FieldQuantitiesOptimetrics.pdf
- EM FAQ: How to export the simulation results/plots of Maxwell?
- EM FAQ: How to quickly fix or heal imported geometry in Maxwell 2D?
- EM FAQ: How to define project variables that apply to all designs?
- ANSYS Icepak: I get a meshing error – “Warning: no mesh exists for block, body”. How do I fix this?
- What are the default boundary conditions in different solvers?
- EM_FAQ: When a DXF file is imported, how can you generate Areas from selected Lines?
- Vacuum Thermal Modeling in ANSYS Icepak
- ANSYS Icepak: How to delete unused materials in a project?
- ANSYS Icepak: O-grid meshing issues
- EM FAQ: How to link the mesh from a static solver to transient solver in Maxwell?
