September 22, 2023 at 11:02 am
FAQParticipantThe magnetostatic and eddy current solvers in Maxwell adaptively refine the mesh until convergence is reached. Since the transient solver is based on time-stepping, the adaptive mesh refinement capability is not available although the initial mesh is automatically generated. One way to refine the mesh in transient solver is by assigning some mesh operations. An alternate way to have a refined mesh in the transient solver is to link an adaptively refined mesh from the magnetostatic or eddy current solver. This document focuses on the latter approach and shows the steps to link the mesh from the static solver to transient solver. Keywords: Maxwell, Mesh linking, transient solver, refining mesh.
1. EM_FAQ_MeshLink.pdf
- EM FAQ: How to export the simulation results/plots of Maxwell?
- EM FAQ: How to quickly fix or heal imported geometry in Maxwell 2D?
- EM FAQ: How to define project variables that apply to all designs?
- ANSYS Icepak: I get a meshing error – “Warning: no mesh exists for block, body”. How do I fix this?
- What are the default boundary conditions in different solvers?
- EM_FAQ: When a DXF file is imported, how can you generate Areas from selected Lines?
- Vacuum Thermal Modeling in ANSYS Icepak
- ANSYS Icepak: How to delete unused materials in a project?
- EM FAQ: How to link the mesh from a static solver to transient solver in Maxwell?
- ANSYS Icepak: O-grid meshing issues
