February 6, 2023 at 2:42 pm
FAQ
ParticipantThe AC resistance is calculated R=P/(I^2), with P the integral of ohmic loss on the concerned conductor. You can check it by comparing the Matrix result and build the resistance from the calculator as the equation above. The formula via the fields calculator is: R=Loss(conductor1)/Current(Conductor1)^2 To implement it the steps are the following: Input -> Quantity -> Ohmic Loss Geometry -> Volume (or Surface) -> (select the object) Scalar -> Integral Input -> Number -> Scalar ->(introduce the current) Input -> Number -> Scalar ->(introduce the current) General -> * General -> / The matrix does: R=Loss(All parts from current in conductor1)/Current(Conductor1)^2
- How do I calculate inductance and resistance of a coil in post-processing phase?
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- What are the available boundary conditions in Maxwell?
- How to create and manage a queue of simulations?
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- Are solid losses and eddy losses the same in Maxwell?
- How to calculate capacitance and inductance in Maxwell Transient solver?
- How to perform a material sweep?
