May 25, 2023 at 7:30 am
SolutionParticipantAdding expressions to expression cache allows Maxwell to record the value of the expression from the field calculator at each user-defined time step without saving the fields at each of these time steps. Please refer to the document for an explanation of the procedure. Keywords: Maxwell, field calculator, expression cache, transient solver.
1. EM_FAQ_How_to_add_expressions_to_expression_caches_in_transient_solver.pdf
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- What are the available boundary conditions in Maxwell?
- Cloud Computing from Electronics Desktop
- How to create and manage a queue of simulations?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- Are solid losses and eddy losses the same in Maxwell?
- Parameters in HFSS 3D Components and design level variables
