September 22, 2023 at 11:02 am
FAQParticipantA Halbach Cylinder is a magnetic arrangement intentionally magnetized so that the field outside (inside) the cylinder is intensified and the field inside (outside) is minimized. If the cylinder (or annular ring) consists of magnet segments, the procedure to model this discrete Halbach configuration in Maxwell would be the same as described in the document EM FAQ: Halbach Array in Maxwell. The only difference being that the segments are arranged in a circle (Fig. 1), instead of a line. In order to model the idealized continuous Halbach magnetization pattern in Maxwell, the procedure described in the following can be used. Keywords: Maxwell, Permanent Magnets, Halbach Cylinder, Magnetization
1. EM_FAQ_Maxwell_Halbach_Cylinder.pdf
- EM FAQ: How to export the simulation results/plots of Maxwell?
- EM FAQ: How to quickly fix or heal imported geometry in Maxwell 2D?
- EM FAQ: How to define project variables that apply to all designs?
- ANSYS Icepak: I get a meshing error – “Warning: no mesh exists for block, body”. How do I fix this?
- What are the default boundary conditions in different solvers?
- Vacuum Thermal Modeling in ANSYS Icepak
- EM_FAQ: When a DXF file is imported, how can you generate Areas from selected Lines?
- EM FAQ: How to link the mesh from a static solver to transient solver in Maxwell?
- ANSYS Icepak: How to delete unused materials in a project?
- ANSYS Icepak: O-grid meshing issues
