Edge coupler
    • SolutionSolution
      Participant
      This example shows how to design an edge coupler for coupling light between a single mode fiber and an integrated waveguide on a photonic chip. A parametrized sweep is used to optimize the edge coupler design for maximum coupling efficiency of the fundamental TE mode of the waveguide. The S-parameters results of the edge coupler are then used to generate a compact model in INTERCONNECT.
      Read the full article here: https://optics.ansys.com/hc/en-us/articles/360042305354
