June 5, 2023 at 7:04 am
FAQParticipantTrim contact only happens at the beginning and it can be used for both small and large deformation. Trim is a tool that is used to remove elements that are deemed unnecessary, so it would only make sense to do this once. To remove them later would change the size of the matrices which would not work.
