Does the transient simulation follow the same procedure as the harmonic simulation (modal analysis, forced response, acoustic response) except that it uses the Transient Structural block to apply the transient forces?
June 5, 2023 at 7:04 am
FAQParticipantThe transient and harmonic analysis will not be solved in a similar way. Harmonic analysis is a technique used to determine the response of a linear structure to loads that vary sinusoidally (harmonically) with time, which is not the case for transient.
