Do the Schnerr-Sauer and Zwart-Gerber-Belamri cavitation models have built-in correction of the saturated vapor pressure in consideration of the pressure fluctuations due to turbulence?
March 17, 2023 at 1:11 pm
SolutionParticipantSinghal-et-al in R6.3 could not account for variations in saturated vapor pressure due to turbulence. Two cavitation models have been added in R12: •Schnerr-Sauer (default) •Zwart-Gerber-Belamri This correction in R13 is possible by the following input command: (rpsetvar ‘mp/pvap/turbulence-factor? #t) Note: Please note that it is not taken into account even in R13 by default. Information on the cavitation models can be found in section 16.7.4 of the Fluent 12.0 theory Guide or section 17.7.4 for Fluent 13.
1. 2041624.pdf
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- What is the superficial velocity in multiphase flows?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
