Discrepancy between field minimum/maximum and evaluation of a field quantity at a point in the same location
May 25, 2023 at 7:29 am
FAQParticipantWhen evaluating field minimum/maximum in the fields calculator, Maxwell utilizes first smooth-function, and then evaluates the location and value of the field maximum/minimum. Creating a point in the same position and evaluating fields at the point will lead into a different results, because smooth-function is used. This is a numerical error and decreases as the mesh is improved.
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- What are the available boundary conditions in Maxwell?
- Cloud Computing from Electronics Desktop
- How to create and manage a queue of simulations?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- Are solid losses and eddy losses the same in Maxwell?
- Parameters in HFSS 3D Components and design level variables
