September 26, 2022 at 9:53 am
FAQ
ParticipantDiscovery – Unable to start SpaceClaim or Discovery after login
Problem: For Named User (Subscription) license, when SpaceClaim or Discovery 2020 R2 is launched and login credentials are specified, the applications don’t start.
Cause: The Named User (Subscription) license is not getting activated after specifying login credentials due to which the applications don’t start.
Recommended Solution: If the applications don’t start, activate the Named User (Subscription) license manually through Command Prompt. Please refer to below article on activating the license manually through Command Prompt.
Discovery Subscription license – Command line options – Knowledge Base – Ansys Discovery Forum
Once the Named User (Subscription) license is successfully activated through Command Prompt, launch SpaceClaim or Discovery 2020 R2. The login page won’t appear and you should be able to launch and use the applications successfully.
- Ansys Discovery Hardware Requirements (2025 R2)
- What’s New in Ansys Discovery 2025 R2
- Discovery License Activation Troubleshooting
- Resolving Error “QA services environment variable is enabled” while opening Discovery products
- FAQ: Resolving Error – ANSYSLI exited or could not read server port ANSYSLI_FNE_PORT
- Changing Named User Subscription or Floating (Enterprise) license option after installation of Discovery products
- Discovery Subscription license – Command line options
- Discovery Family Licensing & Installation
- Discovery: Black screen with no geometry appears after launching Discovery
- ANSYS Discovery: Compatibility Utility
