September 26, 2022 at 10:00 am
FAQParticipantWhether you are creating your own geometry or receiving it from others, you need a single, friendly and intuitive environment to work with them in the same manner regardless of its origin.
Discovery SpaceClaim is that environment, and this page will guide you on your journey of learning in whatever path SpaceClaim takes you on.
- Discovery Spaceclaim
- Getting Started
- Advanced Design
- Model Prep for CAE and MFG
- Reverse Engineering
- Model Prep for 3DP
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- How to setup a Parameter Study
- Discovery SpaceClaim: Getting Started Tutorials
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
- FAQ: Missing Areas of the User Interface in Discovery Live
