Tagged: discovery-aim, discovery-live, installation, spaceclaim
September 26, 2022 at 10:00 am
SolutionParticipantError while installing Discovery products:
instcore.exe has stopped working.
A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
Solution:
Below suggestions help to overcome this error:
- disable antivirus scanners during installation
- make sure to extract the downloaded .zip file before attempting to install
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- How to setup a Parameter Study
- Discovery SpaceClaim: Getting Started Tutorials
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
- FAQ: Missing Areas of the User Interface in Discovery Live
