September 26, 2022 at 10:15 am
FAQParticipantDiscovery Refine : Display issue (Red dots) when viewing Mesh
Problem: Red dots or display issue when trying to view Mesh in Discovery Refine. (image below)
Cause: This issue is known to the development and is suspected to be caused due an issue with NVIDIA driver version 5xx.xx.
Solution: There are a couple of solutions you can try to fix this issue:- This issue occurs only with the NVIDIA Graphics driver version 5xx.xx, so you can update to a newer version (Released march 2022) or revert back one version to avoid this issue.
- The other option is to disable the INTEL GPU from the Bios and then re-install the NVIDIA driver update for version 5xx.xx.
(Please perform these changes with the help of your company’s IT professional.)
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Discovery – Defining new material
- Ansys Discovery: Topology Optimization
- Discovery Quick Tip- Understanding Contour Settings
- How to apply bolt Pretension in ANSYS Discovery?
- Discovery Quick Tip- How to Export to Fluent
- Discovery Quick Tip- Applying Thermal Conductance
- Structural Simulation using Bolt Idealization
