General
General
Discovery Quick Tip – Global Mesh Sizing Controls
    • Watch & LearnWatch & Learn
      Participant
      In this video you will learn about the Global Mesh Sizing Control. You can change the global mesh settings from the Simulation Tab under fidelity settings and select from various options like curvature, proximity, curvature and proximity or fixed. After selecting the global settings, you can turn off use pre-defined settings and access advanced mesh controls like boundary layer, growth rate, minimum size, maximum face size.
