September 26, 2022 at 9:53 amSolutionParticipant
If your network uses a proxy server, additional configuration is required to ensure communication takes place:
- In the Windows Control Panel under Internet Properties, click on the Connections tab and then click on LAN settings to open the right window. Specify proxy server address and its port (refer below image). As always, consult with your IT Department for assistance.
2. Install ansysls_client patch attached at the top if you are using any version prior to 2019 R1, else move to next step 3:
a. Download ansysls_client patch if you are using any version prior to 2019 R1.
b. Go toShared FilesLicensingwinx64 .
c. Rename ansysls_client.exe to ansysls_client_old.exe
d. Copy & paste the contents of downloaded patch in this location.3. Once done, try launching Discovery product. If it doesn’t work, set below environment variable:
HTTPS_PROXY=”https://host:port”;
where host and port are the proxy host and port.
4. Once done, try launching Discovery product. If it doesn’t work, gather diagnostics and send to ANSYS.
a. Open Windows Explorer.
b. Browse to %temp% .
c. Find the directory named .ansys, right-click on the directory, select Send To and then Compressed (zipped) folder.d. Send the resultant file.
- Ansys Discovery Hardware Requirements (2024 R2)
- What’s New in Ansys Discovery 2024 R2
- Discovery License Activation Troubleshooting
- Resolving Error “QA services environment variable is enabled” while opening Discovery products
- FAQ: Resolving Error – ANSYSLI exited or could not read server port ANSYSLI_FNE_PORT
- Discovery Subscription license – Command line options
- Discovery Family Licensing & Installation
- ANSYS Discovery: Compatibility Utility
- January 2023 Subscription Licensing Issue
- Discovery: Black screen with no geometry appears after launching Discovery
