April 12, 2023 at 8:28 am
Solution
ParticipantThese video tutorials will help you expand your knowledge of thermal simulation in Discovery Live. After completing the Getting Started section, follow these tutorials to dive deeper into the transient and steady state thermal simulations. These tutorials use the built-in and additional models provided below.Â
1) Import, Setup & Results: Learn how to import, setup and visualize the results for static and transient thermal simulations.
2) Setup, Edit & Optimize: Learn how to do a basic thermal simulation of a heat sink and optimize the geometry for your given performance specifications.
3) Internal Fluid w/Thermal: Learn how to setup a fluid flow analysis with thermal effect and make changes to the model to achieve different engineering goals.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
- Discovery AIM – Scaling deformation contour results
- FAQ: Missing Areas of the User Interface in Discovery Live
- Discovery SpaceClaim: Getting Started Tutorials
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Project Text to 3D Geometry in SpaceClaim
