Legacy Products
Legacy Products
Discovery Live: Thermal Tutorials
    • SolutionSolution
      Participant
      These video tutorials will help you expand your knowledge of thermal simulation in Discovery Live.  After completing the Getting Started section, follow these tutorials to dive deeper into the transient and steady state thermal simulations.  These tutorials use the built-in and additional models provided below.
      1) Import, Setup & Results: Learn how to import, setup and visualize the results for static and transient thermal simulations.
      2) Setup, Edit & Optimize: Learn how to do a basic thermal simulation of a heat sink and optimize the geometry for your given performance specifications.
      Download File
      3) Internal Fluid w/Thermal: Learn how to setup a fluid flow analysis with thermal effect and make changes to the model to achieve different engineering goals.
      Download File
