Tagged: discovery-live, discoverylive, Live App Example, Live How-to
September 26, 2022 at 9:58 am
SolutionParticipantDownload the file here
Application example of an engine with thermal-stress multiphysics simulation. A heat source is specified in the engine and the temperature distribution through the engine is calculated. The engine temperatures are then sent to a structural simulation, where the thermally induced stresses are calculated. This project requires release 2019 R2 or newer.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
