September 26, 2022 at 9:58 am
FAQParticipantProblem: An error is occurred after clicking “Create Solution” button in Discovery Live interface
Error message: An error occurred while executing “Create Solution”
Cause: This error may appear due to some unintended changes in the user settings
Recommended solution: To overcome the above mentioned problem, reset the user settings. To do this, go to File – Live options – Advanced
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
