September 26, 2022 at 9:59 am
FAQParticipantProblem: Following message appears while launching Discovery Live R19.2
Caught exception:
Object reference not set to an instance of an object. Stability of the application might be seriously affected
Cause: This message is appearing due to Algoryx Momentum add-in. Discovery Live is not compatible with Algoryx with its current UI.
Recommended solution:
Upon disabling this Algoryx Momentum add-in, the message does not pop up. To disable this add-in, go to File – Live Options – Add-Ins and disable this add-in. See below image. Click “Ok” accept the changes. You will have to restart Discovery Live to get the add-in disabled.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- How to setup a Parameter Study
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
- Discovery SpaceClaim: Getting Started Tutorials
- Creating a Helical Geometry in SpaceClaim
- FAQ: Missing Areas of the User Interface in Discovery Live
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
