Legacy Products
Legacy Products
Discovery Live: Internal Fluid Flow with Thermal Effects
    • SolutionSolution
      Participant
      Download the file here
      This tutorial video explains how to setup a fluid flow analysis with thermal effect and make changes to the model to achieve different engineering goals. The video uses geometry modifications and creation to change the simulation. Charts and probe calculators to used to monitor the simulation results.
