Discovery Live: How to define input mass flow rate instead of velocity in internal flow simulations?
September 26, 2022 at 10:00 am
FAQ
ParticipantDiscovery Live currently does not support this feature. You could work around this limitation by manually calculating the equivalent velocity as:
(Inlet velocity magnitude) = (mass flow rate) / {(Density of fluid) * (Area of inlet face)}
The area of the inlet face can be obtained using the Measure tool from Measure tab.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- FAQ: Missing Areas of the User Interface in Discovery Live
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
