April 11, 2023 at 11:58 am
Watch & LearnParticipantThese video tutorials will start you on your journey of learning with Discovery Live. Getting Started begins with a general overview, introduction to each of the physics simulations and the underlying geometry creation and editing tools. All videos use the built in models and can be streamed directly from this page by clicking them.
1) Static Structural Simulation: Learn the basics of how to setup, solve and visualize the results of a linear static structural simulation.
2) Internal Fluids Simulation: Learn the basics of how to setup, solve and visualize the results of an internal fluid flow simulation.
3) Modal Simulation: Learn the basics of how to setup, solve and visualize the results of an modal simulation.
4) External Fluids Simulation: Learn the basics of how to setup, solve and visualize the results of an external aerodynamics fluids simulation.
5) Thermal Simulation: Learn the basics of how to setup, solve and visualize the results of an thermal simulation.
6) Geometry Creation & Editing: Learn the basics of the sketch tools and the Pull Tool to create a model from scratch or edit an existing design
7) Static Structural Topology Optimization (Beta): Learn the basics of how to setup a volume % reduction of a linear static structural simulation, which is currently released as a beta preview.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
