April 11, 2023 at 12:06 pm
Watch & LearnParticipantThese video tutorials will help you expand your knowledge of fluid flow simulation in Discovery Live. After completing the Getting Started section, follow these tutorials to dive deeper into the internal and external flow simulations. These tutorials use the built-in and additional models provided below.
Internal Fluid Flow
1A) Internal Fluids Simulation: Learn the basics of how to setup, solve and visualize the results of an internal fluid flow simulation.
2A) Internal Results Visualization: Learn about the visualization capabilities in Discovery Live when working with internal fluid flow simulations.
3A) Import, Setup & Edit: Learn how to create a basic internal fluids simulation with ANSYS Discovery Live.
4A) Internal Fluid w/Thermal: Learn how to setup a fluid flow analysis with thermal effect and make changes to the model to achieve different engineering goals.
External Fluid Flow
1B) External Setup & Results: Learn how to create a basic external fluids simulation with ANSYS Discovery Live.
2B) Import, Setup & Results: Learn how to solve a basic external aerodynamics simulation using a geometry that is imported into Discovery Live.
3B) External Results Visualization: Learn additional details on results visualization, including contours, streamlines, iso-surface, composite rendering, particles, manipulating results planes, charts and other such items.
4B) Enclosure Manipulation: Learn how to manipulate the enclosure of a external fluids simulation such as change size or add slip symmetry.
5B) Scripted Geometry Creation: Learn how to record and replay the creation of aerodynamic geometry inside of a wind tunnel while making parametric changes.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
