September 26, 2022 at 9:59 am
FAQ
ParticipantApplication example of the flow performance in the coolant side of a heat exchanger is explored. Cool water is passed through the system of hot pipes with and without baffle geometry. Further manipulation and alternate baffle geometry can be tested using the modeling features. This project requires release 19.2 or newer.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- FAQ: Missing Areas of the User Interface in Discovery Live
- How to setup a Parameter Study
- Discovery SpaceClaim: Getting Started Tutorials
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
