September 26, 2022 at 9:59 am
SolutionParticipantApplication example of the flow inside an electronic enclosure is simulated, with the goal of identifying if sufficient flow is passing through the heat sink. The impact of changing the location of the outlets and/or introducing geometry inside the enclosure to divert flow through the heat sink can be investigated. This project requires release 19.2 or newer.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
