May 15, 2023 at 8:32 am
SolutionParticipantGetting started with external aero engineering simulations in ANSYS Discovery Live is as simple as a few mouse clicks, as upfront analysis has never been this easy. Plus, the simulations are instantaneous as you change boundary conditions or quickly make 3-D modeling changes. In a matter of minutes, Discovery Live enables you to find out if your design changes are of benefit or not.
1. 2053382_Captions-EN.mp4
2. 2053382_Captions_CN.mp4
